ECM Pinout diagram- 1993 2.5L V-6 Engine w/Manual Transaxle
Diagnostics
Post by 1stgenWizard » Wed Aug 26, 2020 4:18 pm
Connector Diagrams: Electronic Control Unit/Powertrain Control Module
Pin Wire Color Function
1A Blue/Red Keep Alive Power
1B Red/Black Vehicle Power
1C Black/Red Vehicle Start
1D White/Red Swith Monitor Lamp
1E Blue Malfunction Indicator Lamp (and Self Test Output, 1995-97 only)
1F Light Green/Red Self Test Output (1993-94 Only)
1G Blue/Orange Ignition Control Module
1H White Headlamp Switch
1I Red/White Self Test Input
1J Purple Rear Window Defroster Switch
1L Green/Black A/C Relay
1M Green/Red Vehicle Speed Sensor
1N Blue/Yellow Power Steering Pressure Switch
1O Pink/Black Clutch Cycling Pressure Switch
1P Orange/Black Blower Motor Control Switch
1Q White/Green Brake On/Off Switch
1R Light Green/Black Park Neutral Position Switch/Clutch Pedal Position Switch
1T Brown Idle Switch
1U Black Ground (Manual transaxle only)
2B Red Measuring Core Volume Air Flow Sensor
2C Black/Yellow Right Heated Oxygen Sensor
2D Blue/White Left Heated Oxygen Sensor
2E Red/Green Engine Coolant Temperature Sensor
2F Yellow Throttle Position Sensor
2G Red/White Cooling Fan Engine Coolant Temperature Sensor (1993 Only)
2H Pink/Yellow High Pressure Switch
2I Purple Reference Voltage
2J Red/Black EGR Valve Position Sensor
2K Black/Red Intake Air Temperature Sensor
2L Green Daytime Running Lamp (Canada Only)
2M White Knock Sensor
2O Blue/Black Canister Purge Solenoid
2P Blue/Green High Cooling Fan Relay
3A Black Ground
3B Black Ground
3C Black/Red Ground
3D Black/Blue Ground
3E Light Green/Orange Crankshaft Position Sensor #1
3F Blue Crankshaft Position Signal Return
3G Blue/Pink Cylinder Identification Sensor
3H Green Crankshaft Position Sensor #2
3I White/Green Variable Resonance Induction System Solenoid #1
3J Blue/Red Variable Resonance Induction System Solenoid #2
3L Red/White Low Cooling Fan Relay
3M Green/Black Fuel Pressure Regulator Control Solenoid
3N Blue/Orange Condenser Fan Relay
3O White/Blue EGR Vent Solenoid
3P Green/White EGR Control Solenoid
3Q Light Green/Black Idle Air Control Solenoid
3T Light Green Fuel Pump Relay
3U Red/Light Green Injector #1
3V Blue/White Injector #2
3W Brown Injector #3
3X Red/Yellow Injector #4
3Y White Injector #5
3Z White/Black Injector #6
